Advantages of win7 and win xp
I want to know whether windows7 is better as compared to windows xp or not?which is the most important advantage of installing windows7 as compared to xp as a professional point of view.pls help
The usage of windows is depend on the User's need. For example if you want you PC for gaming so windows 7 is best. Now a days Window 7 is installed in every new Laptop. There is a large number of increase in the Users of Windows 7.
Following are the five most important advantages of Windows 7:
1. Remote productivity.
2. Secure mobile access.
3. Security and control.
4. PC management and Troubleshooting
5. Client Virtualization.
There are many reasons to use win7 over XP.
Firstly win7 is advance version of XP providing you super interface between user and machine.
Aside interface you can’t forget visual advantage. The design and color combinations in Win7 are brighter than XP. ALSO
Support from User Account
More Applications
64-bit computing
Windows XP Mode
Notifications
