Advice about albany verify tcp ports please
How are you experts? I need practical network verification all the time,so please advise about albany verify tcp ports, I will be thankful Regard
Hello Jafet,
In order to verify the TCP port use the following command that will show you which ports are currently in use by the system?
· Click on the RUN
· Type CMD
· It opens the Command Prompt.
· Then type the following command.
· Netstat –an
· Press enter
· Output will be on the screen.
Regard,
Harthy Opera
hello,
in order to verify tcp ports go to command prompt. Then write Netstat -an on the command box. Then press enter.you will get the tcp ports that are active at that time.
it will help you.
thank you
Notifications
