mywork
Posted on - 09/26/2011
I have recently downloaded Google Chrome as one of my web browsers. Every time I try to browse using it, it either refuses to load, or when it loads, it takes time to respond. When it responds, toggling between tabs becomes almost impossible. What program was used to create Google Chrome. Why is it different from Mozilla and Internet Explorer? Finally, how can I solve this problem?
Advice on how best to work with Google chrome.
Google chrome was developed using C++, Assembly and JavaScript Programming languages. Unlike IE and Firefox, Google Chrome was released as an open source program, meaning that any programmer with the required programming skills can edit it to their own liking. There are numerous versions of Google Chrome out there that can be downloaded from different sites. Some versions of Google may be unstable depending where you downloaded them. Please make sure you download from the official Google Chrome website.
Does your computer meet the minimum requirements to run Google Chrome? Please check if it meets these requirements:
- Windows XP or higher.
- Intel Pentium 4 or higher.
- At least 128 MB RAM.
Hello there,
Probably you are using a wireless connection, this is a common problem of Chrome especially when you are using a wireless connection. Here's a process to sort this out. Just follow the steps mentioned below and that's it you wont face this problem anymore-
In the wrench icon of Chrome Go to Options and then select Under the hood and then press Reset to Defaults. Also check the Use DNS pre fetching is unchecked. After that Go to Change Proxy settings and then Go to LAN Settings and uncheck the Automatically Detect Settings and then hit Ok.
Then Go to Control Panel and Select Network Connections. Make sure there you Enable only one active connection which you are using at the moment and disable the rest, then clear you cache and history and Restart your PC and turn it off and then ON it again. Your Chrome will work fine now without any error. Good Luck.
Thanks!!
