Hi Experts,
I have been given a script by my colleage and I want to check it if it is his creation.I seek your advice on plagiarism check script code.I am not a premium member of copyscape and will it affect  this?Help me on this plagiarism check.Thanks.
Jermaineporterr
Advice me on plagiarism check script code ?
Hi Jermaineporterr,
I understand your issue and i have a great experience on Plagiarism check. I have use Plagiarism Checker for checking the plagiarism.
If you want to check any document , you can check only in 3 steps, please visit below mentioned address :
http://www.plagtracker.com/
Through this website you can find that :
   from which source the data is copied
   how much percent data is copied.
I hope it may help you.
Thanks!
Hello Jermaine,
Using copyscape will not affect the script code that your friend send you. Copyscape will simply check if the work is unique or plagiarized. If the work is plagiarized it will present you with the sources to which the work was copied from, but it will not affect the script code of the information.
But in case you might have had some problems with your copyscape application whereby the script code was affected then it will be very clever if you made a duplicate of that work and saved a copy differently so that even when the work you are using to check for plagiarism is destroyed you will have a backup.
Carl
