moss mathew
20 points
Posted on - 08/25/2012
Hi Experts,
I am having mp4 songs and need to convert them to mp3.
Does anyone know about offline mp4 to mp3 converter?
If so advice me.It need to work offline.
It is a key requirement.I tried many software's but did not get the right one.
Moss Mathew
Advice on offline mp4 to mp3 converter?
Hello Moss,
There are many applications online that you can download and use to convert your MP4 songs into the MP3 format.
I will recommend that you get one of the following two:
Format Factory Tool:
This is a quite good tool which is an all-in-one converter that will allow you to successfully convert your MP4 songs into the MP3 format. You can search for it on the internet and download it.
Free Video Converter:
This is an application that will allow you to convert to AVI, MP4, WMV, MKV, FLV, 3GP, MPEG, DVD, Blu-ray, as well as MP3, and therefore you can use it to convert your songs from MP4 to MP3 successfully.
Carl
