balanm
Posted on - 01/11/2012
Hi Experts,
I am expecting to have some sort of portable device i.e. laptop or notebook which I can work on surfing web, playing videos sing Youtube and is fairly light weight. Advice which device do I need?
regards
Bala
Advice on purchase of a portable device
Hello Balanm,
There are a lot of new portable devices in the market nowadays. You should also put on how much budget you have to buy a portable device. Below are the list of good quality laptop and netbooks which you can choose to buy:
Acer Aspire 5742G-384G64Mnkk
The Samsung NC110-AM4UK netbook
The Lenovo ThinkPad X220
The new Samsung Series 5 Chromebook
ACER Aspire Timeline X 4830T
All of them are great and cheap but has high quality. It just depend on your budget. You can also try apple iPad or Samsung Galaxy Tablet if you want.
-Zorian
 This depends on your requirements.
If you want only work on surfing web, playing videos and songs something simple things. You can select any brand under small budget.
I prefer Dell, Acer , Sony .
If you want use your laptop for a harduse ,select the Acer laptop.
If you want a high performance laptop for games and 3d animation .
Select Sony and Dell laptops .
You can find very easily these kind of laptops on the market under your budget.
