noel leal
10 points
Posted on - 04/20/2012
Hi Techy Guys out there!
I wanted to know if anyone of you here, have encountered Kompozer.net?
I wanted to ask if there are similar websites that does the same thing?
Can someone give their own personal feedbacks on the efficiency of the application?
Thanks!
Advice Website Similar with Kompozer
Thanks for your questions.
Actually Kompozer is software of complete web authoring service. It combines any kind of management of web based file. It makes easy editing of web pages. I suggest you to visit this site for enriched info-
You want to know something similar to Kompozar. You can try bluefish editor. It also like Kompozer. You can easily remove or add web file, edit an enriched whatever you want. Here the link of this website. You can also download it from this link-
Here I'm going to give you some more link for your assistance-
In this site you can find more than 40 of similar software to Kompozer. You can also visit here-
Best wishes for you.
