Broadmind
Posted on - 09/30/2011
Hi All,
I got a new router from Cisco called Valet. I am not a technical person so I got confused on how to setup this router. It came with a USB device but I could not find the CD anywhere in the box. So I was wondering, how will I install the Valet without calling their technical support?
Thank you
boskie
Setup my router can anyone suggest
Hi follow this steps below.
1. Insert the Easy Setup key into USB port on your computer.Â
2. Click Connect to your Cisco Valet. And in small print: If you do not see this, open the Easy Setup Key folder and double click Connect. The dialog box did not pop up with the option to click on connect to your cisco valet.Â
3. Follow the on-screen instruction to install your CISCO Valet.
Hi Broadmind,
The Valet by Cisco is very easy to install. It does not require any CDs. You can install the Valet by simply following these three steps.
1. To plug in: the easy setup key includes Cisco connect software backup.
2. To connect: Cisco Valet sets up itself in a few minutes automatically.
3. To finish: after completing the installation, run the program.
Thank you.
Have a nice day.
