After Analyzing Ports MAC I found some questions
Hello..
I was functioning Gentoo Linux additionally the best thing I found is to add USE flags , both globally and per package. So I can have an SFTP-enabled lftp without xmlrpc instead of just whatever the package maintainer decided I should have. Do Mac Ports award something parallel ???
And
After analyzing Ports MAC seemingly installs multiple versions of the identical library to abstain subordination battles across multiple packages.
The obvious downside to this is additional area taken up on your disk.A
disadvantage which i know any other disadvantages beyond it ?
Best Answer by Lambert Huling
Answered By 65 points N/A #154091
Mac is more expensive than Windows but it is worth the price.  A few computer hardwares do not support Macs. Some computer stores don’t stock Mac software. It is always available by mail. Window users will say that Mac no longer exists. Even though disadvantages have been found, Mac is highly recommended. They are better compared to any other machines.
Answered By 0 points N/A #154092
The mascots are in two parts the infrastructure called Mac ports base and a set of available ports used for compiling installing and managing open source software  and one that installs automatically known as Dependencies port for mac ports that allows one to make a binary installers of ported applications to install software on remote computer without using a source code.
