After Apple Update, unbootable startup drive
100 points
Posted on - 03/21/2015
A month and a half ago, I installed a new SSD and everything works well. I followed all the instructions here and everything turns great. Last week, I installed an update from Apple but before doing it, I disabled the TE and re-enabled the kext. I installed the update and enabled TE again. Then I disabled kext and all works well. I did the same exact procedure when the latest Apple update came out. The problem is, the MBP was unable to boot up. I don't know what happened. I have an original installer of OS X and I'm not sure if I just reinstall it and start from there again?
