After Effects have some error on time in a layer.
Someone out there that can help me,
I Have been working on aftereffects every day and never yet encountered this error message.
Something just wasn’t right for sure. Is it something to do with the flow of the time of a specific layer?
Or is my clip is just too long or too short?
After Effects warning: Time remapped layer cannot be RAM Previewed.
Thank you.
Answered By 0 points N/A #125622
After effect program uses a large RAM space for its processing papas. So go to run then type “msconfig” and press enter. Now stop unnecessary running process to speed up your RAM.
Use some RAM utility software to free your RAM and keep maximum free RAM space. You can use RAM free software for it or manually by goes to run then type “tree” and press enter.
Clear your computer by deleting unused or unnecessary files and folders from your computer. For this go to run then type “prefetch” and press enter. Now select all file from here and delete them permanently. Again go to run then type “%temp%” and press enter. Now select all file from here and delete them too.
