I have lots of project done in after effects (Adobe CS 4) and all projects were good and done well.
But yesterday when working with it I got this error, it says that I need to reinstall After Effects. I just update my Adobe and after that I got this error.
I don’t know how to solve this one except for reinstalling, is there another way to solve this?
After Effect error: Magic Bullet Looks is unauthorized – please register or re-install. (512)
(25::16)
After Effects re installation error.
Hello Jimmy London,
I think you will just have to do a reinstallation of the aftereffects application in this case. It seems like when you did the update of the adobe software you are using, the after effects application that you had did not meet the system applications of the updated adobe software. And therefore to eradicate that problem, you will have to get an after effects application that is compatible with the updated adobe.
Just review the system specifications of the adobe software and download an after effects application that suits it. I do not think the data you had created using it will be affected.
__
Regards
Mahesh Babu
