After effects suddenly closed down because of an error.
I need help.
My Adobe After Effects program suddenly and unexpectedly quit.
Does anyone of you experiencing the same issue with this kind or program?
Is it also something to do with my plug-in or some third-party effect?
Thanks a lot.
After Effects error: getting size of handle — a bad parameter was passed.
( 23 :: 23 )
Thanks for your help.
Answered By 0 points N/A #125565
After effect error showing because of some wrong command or missing plug-in. Install some plug-in can be solved this problem. There are many plug-in for after effect on the internet. Just collect some and install or replace with others.
If in your computer you install some similar application program in a same time then uninstall one program, this problem occurs. Similar application share similar file they have and uninstall one program can take that similar file with it. So this error shows.
Other option is to uninstall this application program and use some pc cleaner software and then reinstall it again. It will recover the damage of after effect site.
