patty white
10 points
Posted on - 08/07/2012
Hi experts,
I set up a number of softwares and now the error message appears:
“Received exception: Assertion failed in MeshPacket.cc, line 2550: this_mp && this_mp->numOwners”
in .trn file:
"ERROR: MeshPacket 12 does not exist."
Need your help please.
After installing different softwares error message appears
If this is the first time that this happens, try restarting your computer then try it again. Depending on what software you installed, try launching it again after booting the machine then see what happens. If this doesn’t solve anything, try uninstalling the applications you previously installed one at a time checking each application before removal.
For example, you have installed 4 applications. Launch 1 of the 4 applications to see if it’ll work or not. If it doesn’t, uninstall the program then restart your machine when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostic test on your computer, use a disk utility application like Norton Utilities. Install the program again then see if this fixes the problem. Repeat this procedure on the remaining 3 applications to isolate the problem. I think 1 of the applications you installed may have encountered a problem during its installation. You should also check the system requirements of each software you installed to be sure of its compatibility with your operating system.
