What could be making my Samsung galaxy note to start rebooting after I install devise firmware? I got some firmware update on my Samsung galaxy note recently and I install the firmware, but after the installation the device starts to reboot whenever I open any app. How could I fix the problem?
After installing firmware, Samsung galaxy note start rebottling.
Hello Patrica C Lahr, There is no way that your Samsung glaxy note starts rebooting after installation of devise firmware. You may have overflow the stack. There may be no more space for apps storage so that your note start behaves unexpectedly. You have to check and empty some space to make a smooth operation of your device.
There are seems to be a non-compatible issues between the firmware that you have installed into your Samsung Galaxy Note. What you could perhaps do is to uninstall the firmware. Or, you may at least check properly if the firmware is compatible with the version of your current system. Another option is to reset your device to its original settings.
