After installing Ubuntu 10.04.3 I tried to install CCS-5.0.1.00026-Sitara-ARM
Hi Experts,
After installing Ubuntu 10.04.3 I tried to install CCS-5.0.1.00026-Sitara-ARM.
I received an error message which is attached below. I do not know about the message which indicates Application Error
Error: Error in action Execute Action Error in action Execute Action Error in action Execute Action
If you have any idea regarding this error message please help me.
Thanks in advance.
Error: Error in action Execute Action Error in action Execute Action Error in action Execute Action”
Answered By 590495 points N/A #145372
If this is the first time that this happens, try restarting your computer then try it again. Restart whatever it is you are doing after rebooting your machine then see what happens. If this doesn’t help, you should check again the compatibility of the software with your computer by checking its system requirements. Your computer should first meet the necessary system requirements of the software before it can actually work.
You can check the system specifications of the software on the website where you downloaded the installer. The site usually lists the important information about the product like its system requirements, tips, supported file types [if applicable], frequently asked question [FAQs], major features, functions, and others. If you really want to install the software, visit its official website then download the version applicable for your operating system.
