After Installing Vuze 4.7 I am encountering Problems
I can’t make any changes within the advanced search filter on my left screen and I can’t add/edit any of my templates because the Add/Edit button disappears below the bottom of the screen. And I can’t also scroll down that far. This happens after I installed Vuze 4.7 to my newly re installed Window XP. Do you have any advice about this?
Answered By 0 points N/A #103287
Are you sure that the vuze application that you installed was downloaded from a trusted site? Because what I am suspecting here is that the setup you use for installing vuze had malware or a virus embedded in it, and therefore that virus is on your computer and it is the one responsible for those problems that you are receiving.
  • As a resolution to that, you will need to run the system restore utility to remove the viruses and malware that have been installed on your system. Make sure that you restore the system to a time prior to the installation of vuze.
  • Also scan your computer with the antivirus that you have on your computer. Make sure the antivirus is strong and up to date.
-Richard Gabriel
