After mini paint java download nothing changed ,why?
Hi experts,
Mini paint java is not working properly ,it seems that i should change some codes or functions before downloading, to make it functional.
Thank you for your help
Hi experts,
The best way to learn the mini paint is tutorials from different websites.
For web site based tutorial you may go to the-
http://forum.codecall.net/topic/58137-java-mini-paint-program/
If you want to learn from Youtube.com as video tutorials, just visit-
or,
You will also obtain the necessary codes for this software in those websites.
It is not working properly. There may be some issues happened:
1. While downloading, the download was encrypted.
2. It may be the demo version. So every service is not allowed to use.
3. It may be an old version.
4. It was not installed correctly.
You should try the following solves:
1. Download the latest Mini paint version from the web
2. Be sure that while you were downloading, the download was not encrypted. This also causes softwares corrupted.
3. Re-install the software.
Hope there will be no more problem.
Notifications
