stephen52
10 points
Posted on - 08/10/2011
My computer is running properly, everything is okay but after sometimes computer is being hang. I've checked my CPU, I've seen that after some times processor cooling fan is being stop & processor is being very hot. I need a solution. This problem is coming from 3 weeks.
Jack034
After some times is being stop processor cooling fan
Your PC is having some problem. I think your PC RAM is not high. Sometimes There is a problem in RAM. Check your RAM is okay or not. If your RAM is okay then Your motherboard might have been the problem. Sometimes motherboard cannot supply commands to each device. There might be some problem in motherboard BIOS.
Your Hard disk is okay but your other component have problems. If you can open the CPU, you might discard RAM and clean the RAM plate( colored gold) with an eraser . After cleaning place it and check it again. If you still facing problem consult to your nearest service center or replace your components..
I hope this might work.
    Many computer faults are caused by overheating due to poor airflow .This kind of problem is not related to ram nor the hard disk which is configured with the CPU when the temperature is extremely high the processor fan stops working or it reboots. Its very important to clean your computer in regular intervals this will also help your PC to maximize its life span you do not need any special skills to clean your PC .
  After cleaning of your PC components don't close the cabinet box completely leave one side of the cabinet box un-screwed such that the air flow will help in balancing temperature. By doing this you won't face any kind of processor problems.
