After The Normal Usage Of Computer, It Gives 0xc4 Error
Explain the 0xc4 error? Describe the cause of the error code and explain the solutions to troubleshoot this error message?
Unexpected error named as 0xc4 error which is a boot error for Windows 7, 8, 8.1, or 10 operating system. Error code 0xc4 also known as DRIVER_VERIFIER_DETECTED_VIOLATION. The symptoms of code 0xc4 are the screen will become blue with a bunch of words and numbers telling you something caused the failure. It is a sudden and unexpected event that happens without warning. The cause of the DRIVER_VERIFIED_DETECTED_VIOLATION Error 0xc4 is faulty hardware or software corruption, driver incompatibility, and operating system corruption. The solution to fix the 0xc4 error code is as follows:
Solution 1:
Uninstall and reinstall the Windows Operating System.
Step 1: Go to Start menu and open ‘Programs and Features.’
Step 2: Find the software that is linked to **insert file name**
Step 3: Click on Uninstall and complete the process.
Step 4: Restart the system and reinstall the program.
Solution 2:
Uninstall the external hardware.
Solution 3:
Restore the system.
Solution 4:
Run the system in safe mode.
The snapshot of the error is shown below:
