Jeo Tolbert
Posted on - 10/04/2012
Hey guys,
After windows automatically downloaded an update, I cannot open Turbine Downloader.
Can anyone give me some assistance with how to solve this problem?
I have an image of the error below.
Thank you very much.
Some files from your computer are renewed which are cause in registry update or may be it is defected and that's why you are not able to launch the program to solve the problem you can either reinstall the software or can set a restore point from your previous reset points to make it as it was working previously.
Smith Thompson
Hello Jeo Tolbert,
In order to cancel this update you need to do a system restore. Please do the following:
– Click Start
– Click Help and Support
– Search for System Restore
– Restore your system to a date that is before the computer updated
– Computer will restart and hopefully your problem will be resolved
I advise you to turn off Automatic Updates from Control Panel to prevent this in future.
