Randy Baier
30 points
Posted on - 06/13/2012
Hi all,
I keep on getting this error and have no idea what it means:
"Whew!
Thanks for putting 110% into signing up for AOL accounts.
Love your passion! We'd also love a quick break to process your requests. Take a breather. Maybe grab a bite? You may qualify for additional registrations in 24 hours.
Error code 420"
Is this a virus of some sort?
AIM error, can’t create account?
AOL Error Code 420: unluckily this error code does not permit users to access their account likewise it does not allow also new users to sign up for a new account. Maybe your computer’s registry has a corrupt file or your running two on it, or your computer maybe has contracted some virus and it’s the reason of the interruption of the communication between your computer and the AOL.
To figure out some ways to manually fix the AOL code error 420 problems, depends on what really the cause is. Walk yourself through the step by step approach on fixing the error, hit the link.
Here are different ways how to fix error code “420” in AOL. First, try checking the browser you are using. If you normally access AOL with Microsoft Internet Explorer, try using another browser. For example, start Mozilla Firefox then go to the AOL Homepage and log in to your account.
If you logged in successfully with Mozilla Firefox but not with Microsoft Internet Explorer where you received error code “420”, this verifies that the problem is with Microsoft Internet Explorer. Try updating Microsoft Internet Explorer. Another suggestion to fix error code “420” is to scan your computer for possible virus infection. Update your antivirus or internet security then perform a full system scan on your computer.
Also, try using Sophos. Download Sophos Virus Removal Tool and install it. Once installed, start Sophos then wait for the virus signature database to get updated. When updating is complete, click to start scanning your computer. The tool scans everything on your computer including external devices connected via USB port.
When a virus is found at the end of the scan, remove or delete it then repeat the scan over and over until it no longer detects a virus. See if this works.
