Aimersoft dvd to psp converter
Hi and good day!
I have 3 full movies that I want to play it on my PSP. How to Convert DVD to PSP MP4 Video using Aimersoft? Is Aimersoft DVD to psp converter useful?
Thank you.
Elizabeths Land
Hi and good day!
Thank you.
Elizabeths Land
• Transfer DVD to the DVD to PSP converter.
Insert disk to DVD-ROM, then click "Add…" to browse your PC, and select the DVD folder, ISO file or IFO file you would like to convert.
• 2 Set DVD splitting output choices.
Select correct output format from the drop-down list of "Profile" and destination folder for your DVD movies. Here we select PSP Video MPEG-4 (*. mp4) within the class of Game hardware. You furthermore may will select PS3 because the output for your DVD movies. Simply choose the one you would like.
You can additionally set up the resolution, frame rate, encoder or bit rate of video and also the sample rate, channel, encoder or bit rate of audio to attend to your each need.
• 3 Convert DVD to PSP MP4.
After all necessary settings, click "Start" to rip DVD to PSP. And you'll be able to preview the output video and see the method of conversion whereas changing. The conversion time depends on the scale of the DVD that you simply loaded into the DVD converter.
After the conversion is completed, you'll be able to simply notice the converted MP4 files on your PC by clicking "Find Target". Merely drag them to your PSP, and you're able to enjoy the DVD movies on your PSP.
Notifications
