Ainol Novo 7 Elf 2 can any one suggest?
Hello world,
Hello world,
Dear Eathon Mandel,
I see you are deciding if it’s worth buying this tablet. Just by looking at its specifications, I can say at first glance that it’s definitely worth the buy considering it’s on sale on their website:
Now to get into deeper details:
On the downside:
Those are the most important aspects you need to consider before buying. I hope I’ve made myself helpful.
Hello Eath,
In Recent Days Tablets Have Become Very Popular. They Are Bigger Than Smartphones And Smaller Than Laptops. So, If You Are Looking Forward To Buy A Tablet Then I Would Say That You Should Go For It. Now Lets Get To The Point. I Must Say That Ainol Novo 7 Elf II is A Great Tablet.
It's Advantages are:
1. Ainol Is The Most Popular Among Chinese Electronic Device Manufacturers. It Has A Good Reputation In The Market.
2. It Has Got Dual Core Processor.
3. It Has HD IPS Screen.
4. It's Cheap.
5. It is Slim And Has A Camera Too.
Disadvantages:
1. It Doesn't Have Bluetooth, GPS.
2. There Is No built-in 3g version. But you can use some of the 3g dongle.
3. Comparatively Small Battery.
But, If You Can Raise Your Budget A Little Than You Can Think About The Google Nexus 7 Or Samsung Tab 2.
Dear User,
This tablet is a very good one. And it is android based. Below is the quick overview of the tablet
Al so this supports flash and with, an in built camera too.
Personally I would go for it because the price is worth the product
Thank you.
The screen does look good at 100% brightness. Being 1028×760, but the viewing angles are where the device show its weakness. Straight on the viewing it seems to be the best non IPS screen I have seen on a 7 inch with colors really popping. But game playing is very enjoyable with the dual core being obviously an advancement. As well as the movie playback using the native video player is very good.
