Hello guys
I have recently installed aiprosoft MOV video converter 4.0 and it was installed successfully but now when I try to load it, I get an error.
The screenshot of the error is attached below:
The message states:
Aiprosoft MOV video Converter
Load error
Anyone can please help and tell me why it is not loading and what might be the reason behind this?
Looking forward to your replies
Kindest regards
Aiprosoft MOV Video Converter 4.0 : Error
Hi the problem could be that your loading a file format that would not be supported by the converter.
An example of such a type of file would be something like fraps.
Aiprosoft does give such a error when you load an unknown file format.
Solution: try loading a different file or download a different converter such as Aiseesoft total video converter
I think the file format is not recognized by the software so you need to use other software.
Format factory is a very good option for you. If you use that then you can convert any format.
Or try to download the full version of that software.
I think that will help you.
Thank you.
