On my Samsung GT-I8000 (OS Windows mobile 6.1pro) after each conversation (incoming or outgoing doesn't matter) says that phone is off and turns on airplane mode. I don't know where and how change it. I did drop my phone couple of times, but nothing broke and there was no water or anything.I would appreciate your help. Thank you.
Airplane mode turns off automatically on Samsung GT- proI8000
Hello Rebecca Green,  Always turn off the Airplane mode. You can turn off by going into menu then setting, then airplane mode, then off it. You may accidently switch on the mode. So ensure this. Also if this happens repeatedly, Then there would be any hardware problem which does not seem from outside. So go to the care center and have a service of your phone.
Try to hard reset to your mobile.Â
Before are that save all of your data.
Then take off your battery and then press the restore button on the back of your mobile by using the pin.
Also check that your mobile does not have a timer airplane mode, which turn to airplane mode after some time.
