Airturn BT-105 Pedals not responding with iPad
I started using my newly bought Airturn BT-105 pedals. I intend to use it on my unreal Book application in my iPad. But it seems like it is not working. I successfully paired the pedals on my iPad and the light goes on when pressing the pedal, but the application is not responding. What is causing it to stop responding? How can I fix it?
Best Answer by Natty Proff
Answered By 0 points N/A #94550
This problem does not commonly occur. If you have succeeded with pairing your iPad to the Airturn BT-105 pedals then the problem must be with the software. Some of the software/applications on the iPad are not yet supported by this device. Check if the software you are using is among this one and consider changing to a supported software. If the problem persists, feel free to share it out.
1. AirTurn's App Guide for the iPad 1503
2. AirTurn's Worship App Guide 1101
3. Avid Scorch for iPad 1109
4. DeepDish GigBook (iPad) 2934
5. EBookDroid (Android 3.0) 439
6. forScore (iPad) 4424
7. MobileSheets (Android) 308
8. Moon+ Reader (Android) 248
9. Musicnotes Sheet Music Viewer for Android 240
10. Musicnotes Sheet Music Viewer for iPad 1150
11. MusicPodium for iPad 1754
12. MusicReader PDF for iPad 10013
13. NextPage (iPad) 2192
14. NextSong for iPhone/iPod/iPad 1887
15. OnSong (iPhone/iPod Touch/iPad) 4387
16. Partitions: Digital Sheet Music for Tablets: PDF, iPad, ePub 1578
17. Planning Center Music Stand (iPad) 2497
18. SampleWiz (iPad) 403
19. Scorecerer (iPad) 2435
20. Scorio Music Case (iPad) 240
21. Sheet Music Direct for iPad 489
22. SongBook Chordpro (iPhone/iPod/iPad compatible) 5580
23. Teleprompt+ for iPad 2382
24. UnrealBook (iPad) 3087
25. Virtual Sheet Music (iPhone/iPod touch/iPad)
Answered By 5 points N/A #197321
This does look like that this software does not supports the Ipad. This seems to be the main reason that is causing the problem. You need to insure that you use any other software for page turning and insure that that supports the Ipad. It is very important to insure this or else you are going to encounter such problem again and again. There are number of page turner software and you can use anyone of them.
