Aiseesoft Audio Converter for iOS 6
Aiseesoft Audio Converter is my favorite Audio Converting and Editing software, which convert any video and audio to all popular video formats. I have been using in my Windows XP. Recently I brought iPad with iOS 6, I would like to know whether Aiseesoft Video Converter will support my iPad. Please guide me. If it doesn't support, please suggest me an alternative software.
Best Answer by Mary I Pendleton
Answered By 40 points N/A #189073
Aiseesoft Audio Converter really is a great converting tool but unfortunately, this software is not supported in iPad. You can search for audio/video converting apps in app store, there are lots of alternatives available. Here are some suggestions –
  1. Syncios -a syncing app that has both audio and video converting tool.
  2. Ultrafast Video Converter – a video converting app.
  3. Convert Audio – audio conversion app.
All the above apps are available in app store, you can try searching for more conversion apps that will suite your need.
Cheers,
Mary I Pendleton
Answered By 45 points N/A #189075
Hello Mike,
Apparently, your Aiseesoft Audio Converter is a version of Computer units only. But if you really want Aiseesoft product then try this Aiseesoft Total Video Converter which definitely supports your iPad iOS 6 and it comes with different versions. Try also Xilisoft iPad MagiC and  Syncios Transfer & Converter that runs on the same OS your iPad have. I hope this helps.
Answered By 55 points N/A #189074
Hello Mike Atherton,
There is no version available for iPad of Aiseesoft. But you can convert the videos and audio into the iPad formats from your  PC. But till now there is no version available for iPads. You can download it form the link given below.
http://sgreocbu.lowcostoem.com/browse/search/?q=Aiseesoft%20iPad%20Video%20Converter%203%20MAC
