Aiseesoft iphone software conversion tools
Hi experts,
Is there a specific way in the Aiseesoft iPhone software that I can automate conversion of videos from different formats of videos available on Internet to iPhone compatible format.
Hi experts,
Hello Kurtra Bon,
The iPhone is the most popular phone in the world.
There are a lot of features and specifications of the iPhone that make it so popular.
For video conversion, you can use the Video Converter app. It is the best converter app for iPhone.
However you must pay to use it. It costs $2.99.
Buy it here Download iTunes.
If you need to convert videos to a format compatible with iPhones and other iOS devices, try using Format Factory. Just download and install it. Note: this is an ad-supported program so read before you click when installing to avoid installing unwanted applications because it is bundled with other programs. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
Another program you can use is ImTOO MPEG Encoder. It supports Windows XP Service Pack 2, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It supports converting videos compatible with iPhone, iPod, and Apple TV formats. Try also using HandBrake. It includes video conversion profiles specific to Apple devices.
