ann tanner
20 points
Posted on - 05/21/2013
Hello Techyv Friends,
I have heard about Aajx as a technique for creating fast and dynamic web pages. I would like to know about, from should I get Ajax download file example freely from the Internet, which will help me to have a clear understanding about Ajax.
Thanks in Advance,
Ann Tanner
Well, AJAX (Asynchronous Javascript and XML) is a platform (programming language) that basically enables users to create functions and web applications that run in the background without reloading or refreshing the whole page. It is not one platform as most may think. It is a combination of a couple of them, mainly HTML and CSS. AJAX came about in an effort to create dynamism in web design.
You can download the AJAX free control toolkit by clicking here. The toolkit provides you with great control in an easy to use platform with minimum knowledge of coding. You will soon be building interactive and responsive web-based applications.
