Hi Everyone,
I need to implement a Chained Ajax Vertical Menus using PHP. I am fresh to PHP and would like to have the notes along with coding on this regard. Please do the needful by providing any online materials.
Thanks
Scott Athers
Ajax vertical menus using PHP
Dear user,
I have done a few minutes research for your query on Google and have found some PHP codes that may help you. These scripts are easy enough and will work too. I have attached them with the solution, first one also has its PHP response.
Hope this will help you.
Thank you.
Try this code :
$query = mysql_query ("SELECT * FROM menu ORDER BY primary ASC");
$parent=0;
$sub=0;
Echo "<UL>"; //start list
While ($menu = mysql_fetch_array ($query) {
  If ($parent != $menu ['PID']) {//if not seen the item before
     If ($sub != 0) {echo "</UL>";} else {$sub++;} //if not first submenu, close submenu before. If first sub sub++.
     Echo "<UL>";} //open submenu
  Echo "<Li>". $menu [CID]."</Li>"; //echo item
  If ($parent != $menu ['PID']) {//if not seen before
     $parent = $menu ['PID']; //set to see before so next loop will be recognized
Echo "</UL>"; //end list
This link will help you:http://www.lotusseedsdesign.com/blog/magento-vertical-categorymenu
