I have a 16 GB LTE iPad with the Dual Core A5 chipset. I was wondering if I can install AJAX-ZOOM on my iPad? I use AJAX-ZOOM on my e-commerce website to convert images by batch and view in full screen. It would be a bonus if I could put it on my iPad as I am now always on the go. Can AJAX ZOOM image full screen capable in iPad?
Is Ajax zoom image full screen capable in iPad?
Hello , Robert L Kirchner
Hope you are fine.
AJAX-ZOOM is a powerful image zoom & pan plugin with 360° rotate option, jQuery image gallery option. With over 300 other options AJAX-ZOOM is very flexible. It doesn't require any browser plugins as for example Flash, Silverlight or Java. The most interesting thing is that it works great on iPhone/iPad and other mobile devices. It is also a perfect y tool for E-Commerce.
Hope you will get your answer.
Hello Robert,
The AJAX ZOOM image full screen is very compatible on your Ipad(without Flash Plug in).If you know how to use it correctly.Possibly,It depends still with the model of your iPad.AJAX ZOOM image full screen is a unique and powerful 360/3D spin and zoom java script If you have also an Iphone/Ipad with 32 GB you can also install the AJAX ZOOM image full screen.If you have save this program to your iPad you can use it any time you want as long as your iPad still exist with it.
