Alcohol does not load drive drivers, how can i solve it?
Asked By 7060 points N/A Posted on -
I am very fond of playing games and I need to make Virtual DVD to mount ISO Images of games. For this purpose, I installed Alcohol 120% to my computer. Its installation is perfect and at the last it displays the error message as follows; Loading Alcohol device drivers failed! Emulation options and native driver interface of Alcohol 120% will not be available! Kindly, guide me well to overtake this problem. I shall be very grateful to you.
Answered By 590495 points N/A #80619
I also once used Alcohol before because of a game that requires its CD to be loaded every time it is played. That’s why I installed Alcohol to clone and create a virtual CD so that instead of inserting the original CD, the virtual CD I created is automatically loaded on the virtual CD tray. The hassle of manually inserting the CD in the CD-ROM drive is eliminated.
If Alcohol is frequently having problems running in your system, might as well replace it. Find a quite newer version that might run more efficiently in your operating system. And to get you more acquainted of why Alcohol is constantly getting error when running it, read the documentation of the program. Browse the folder where it is installed and look for a readme.txt file. Open it by double-clicking and see if the System Requirements of Alcohol is listed there. So you will know what specific version of operating system it will run.
