Hi to everyone,
All about compatibility of adobe premiere 32bit. Is this application compatible with Windows Operating system and Mac Os? I have to install adobe premiere software in computers with both Mac and Windows Os. Also add some antivirus information that may possibly block the installation and execution. Thanks.
 Your suggestion is very much welcome.
nipuhoq
It does not matter if you are currently shipping Mac qualifies but ancient Mac and windows Os do not support so you make sure this system support
There is actually no problem installing Adobe Premiere on computers that are running on either Microsoft Windows and or Macintosh OS X. Both of these operating systems are supported but I’m only quite confused on the specific version of the software you are asking since there are lots of different versions of Adobe Premiere that have already been released.
Adobe Premiere is released on different versions to make it compatible with the computer’s architecture. The versions of this software are available in either 32-bit or 64-bit and should not be interchanged when installing. You should check first the computer’s operating system before installing it to avoid incompatibility problem. If your operating system is on the 32-bit side, you should install the 32-bit version of Adobe Premiere and this also goes to the 64-bit version. Installing the wrong version will make the software to not work at all and sometimes faulty if you are still able to install it.
