Hello experts,
All about converting wmf for latex. How can I convert or import this wmf files in a latex document? Give me some step by step process if possible that will help me to solve this issue, I know you have some bright ideas based on your experiences come share it with me. Thank you.
Hi
Firstly you need to convert .wmf file into .eps file. Because The .wmf graphics format is not supported directly by any Tex engines. Thus the files will always have to be converted to .eps or .pdf format. Now you can insert .eps or .pdf file into your latex documents. Here is the way to insert .eps file:
Step 1. Go to Insert Tab,
Step 2. Select Insert
Step 3. Select .eps file and click Ok.
Hello Benjamin,
I came across with this solutions, I hope this will also work with you.
You have to convert your .wmf files into accepted vector format then convert it to pdf file can be downloaded from here: http://www.pdfforge.org/pdfcreator so as to insert it to Tex file using graphic package at https://ctan.org/pkg/graphicx and include itsinclude graphics command.
Good luck.
