All about creating login forms vb6 code.
Hello techyv,
All about creating login forms vb6 code. I want to create a hotel reservation system using visual basic 6 programming language.
I am still on the log in structure part, can you share with me some codes to make it easier for me to construct a login form?
Expecting some help from you guys.
Best Answer by Scott Aust
Answered By 5 points N/A #165924
Hi Young,
Here is a sample login function for VB6.
Private Sub cmdLogin_Click()
     If txtUsername.Text = "" Then
           MsgBox "Invalid Username"
    ElseIf txtPassword.Text = "" Then
            MsgBox "Invalid Password"
     Else
            login
     End If
End Sub
Private Sub Command1_Click()
         frmExit.Visible = True
End Sub
Private Sub Form_Load()
    Me.Top = (Screen.Height – Me.Height) / 2
    Me.Left = (Screen.Width – Me.Width) / 2
    frmLogin.BackColor = vbWhite
    connect
End Sub
Function login()
Set rs = New ADODB.Recordset
            rs.Open "SELECT * FROM PASS", cnn
    While Not rs.EOF
        If txtPassword.Text = rs.Fields!pw And txtUsername = rs.Fields!username Then
            MsgBox "Login Successful.."
            frmLogin.Visible = False
            frmMain.Visible = True
        Else
            If txtUsername <> rs.Fields!username Then
            MsgBox "Unregistered Username"
            txtUsername.SetFocus
            rs.MoveNext
            Else
            MsgBox "Password Incorrect"
            txtPassword.SetFocus
            rs.MoveNext
            End If
        End If
   Wend
End Function
Hope this helps.
Answered By 0 points N/A #165926
Simple Login Code for Admin user or Admin area using vb 6.0
If Text1.Text = "admin" And Text2.Text = "admin password" Then
frmloading.Show
Else
MsgBox "INVALID username & password", vbCritical, "ERROR"
End If
End Sub
Private Sub Command2_Click()
Text1.Text = ""
Text2.Text = ""
End Sub
Private Sub Command3_Click()
End
End Sub
(In command1_click ‘text1.text is the username and text2.text is the password’)
Command1 = login button
(In command2_click ‘text1.text is the username and text2.text is the password’)
Command2 = cancel button
Command3 = exit button
Answered By 0 points N/A #165925
You can take help from daniweb go to the link software development. You have two text fields.
ID and Password. Here is the code
Private Sub txtpwd_KeyPress(KeyAscii As Integer)
    If KeyAscii = vbEnter Then
        If Len(Trim(txtlogin)) > 0 And Len(Trim(txtpwd)) > 0 Then
            If CheckPwd(txtlogin, txtpwd) = "ok" Then
                MsgBox "Password ok"
            Else
                MsgBox "Wrong password or Login not found."
            End If
        Else
        MsgBox "Login and password should not be blank"
    End If
End If
End Sub
Private Function CheckPwd(cLogin As String, cPwd As String)
'in my case i will use dao. you probably using ado just convert it
Dim rs As Recordset, ret As String
Set rs = opendatabase("c:templogin.mdb").openrecordset("select * from tbllogin where ucase(trim(logname)) = '" & UCase(Trim(cLogin)) & "'")
If rs.RecordCount <> 0 Then
   If UCase(Trim(rs("pword"))) = UCase(Trim(cPwd)) Then
       ret = "ok"
   Else       ret = "wrong"
   End If
Else
 ret = "wrong"
End If
rs.Close: CheckPwd = ret
End Function
You can take help from these link
http://www.freevbcode.com/ShowCode.asp?ID=6242
This code takes input from the user as username and password and you can see that the textboxes used in the code
txtlogin and txtpwd explains it. The password will be ASCII characters and the user name used should be varchar.
