All About Exchange Management Console 2010 In Detail.
I am making a project on Exchange 2010 and I want to know more about the Exchange management console 2010 to complete the project. Help me out.
I will brief you about Exchange management console 2010.
The EMC is a Microsoft Management Console based tool which provides Exchange administrators with the graphical user interface (GUI) which helps them manage the configuration of Exchange organizations.
The common user interface elements in EMC
1) The console tree is placed on the left side and is controlled by nodes that depend on the server you have installed.
2) The result pane is in the centre of the console. Based on the nodes selected, the pane displays objects.
3) At the bottom of the result pane, there is the work pane. Here, objects are displayed based on the server role which is selected Server Configuration node.
4) On the right side of the console, the action pane is located. The actions are listed here based on the object selected in the console tree.
