Hello techyv,
All about FIFA 11 for window 7 ultimate. I just upgraded my Windows 7 operating system to Windows 7 ultimate OS, I am just wondering if my FIFA 11 game will run in this new OS?
Does FIFA 11 compatible with Windows Ultimate?
Please let me know if there are problems between the OS and the game play so that I won’t install it anymore for security measurements.
Expecting some help from you guys.
Thank you.
All about fifa 11 for window 7 ultimate.
Hello Lindsay,
So, you like to play FIFA 11. I like to play the game also. But why you are not playing FIFA 13 instead of FIFA 11? Are you playing the FIFA 11 via LAN? That’s good.
By the way my operating system is Windows 8 and before that I was running Windows7 Ultimate and installed and playing FIFA 11. I did not face any problem at all.
So, from the practical view, I can tell you are not going to face any problem.
Have a nice day.
Hey Lindsay,
FIFA 11 is not compatible with Windows SP1, but its compatible with Windows Ultimate and it works fine on my HP Windows Ultimate Platform.
I play it everyday, and no problems so far.
So yes you can give it a try, it'll definitely work.
If it doesn't work either way then you can just restore your system to the previous restored points.
What's the big deal?
Hope it helped!
Regards!
