elidal todd
20 points
Posted on - 01/21/2013
Hello friends,
All about free angry birds for galaxy tab.
What are the kind of angry bird version which is capable of dealing with android operating system?
I tried some before but they the android OS is not allowing such applications.
Please give me the exact solution or suggestion about this issue.
Thanks and Regards,
Elidal Todd.
Hello Elidal Todd,
Angry Birds have 4 versions: – Seasons. – Rio – Space – And the latest is Starwars. It is very easy to find out which versions are supported on you Tab. Make an account on Google, connect your Tab to the internet and open Google Play store using your account.
Now in the search bar type "Angry Birds", the store will show you results in which only those versions would be visible that are compatible with your Tab. Please visit Xda Developers website to find out more about how to run applications that are not compatible with you Tab.
rowansen
On different android systems you will find a setting called "unknown sources" referring to application that is not in the palystore.
You will have to tick it. then you Google "download apk games" or just "apk".
I download angry birds from 4shared.com. Just register and download , very easy.
like i said in Google you will get a lot links where the apk games will be free. apk is the extension that android is using for their applications.
