Jeremy Jack
30 points
Posted on - 12/14/2012
Hello techyv,
All about how to add Bluetooth usb to ics tablet. What is the step by step process of the proper installation of Bluetooth usb driver in ics tablet? I have to be aware on the process so that the next time I will insert Bluetooth devices it won’t be so hard anymore. The office needs to transfer files every day and we need to acquire Bluetooth usb device.
Expecting some help from you guys. Thank you.
All about how to add Bluetooth USB to ics tablet.
I can help you to install a Bluetooth to your tablet. It is very simple; I will guide you with the steps.
>>Insert the USB in to your tablet.
>>A popup will appear “found new device”.
>>In certain cases, the tablet will automatically install the driver for that device.
>>In case, if it does not install, you can manually install it from the website.
>>Click on the Bluetooth device and select its properties.
>>You can see an option to update the driver.
>>Click on that and update the driver.
That’s all you have to do.
Thanks and regards,
Skarbos Jay.
