Hello fellows,
All about how to make sliding puzzle in flash as2. I already collected 10 pictures for my sliding puzzle project using flash as2 software application. Would you mind sharing some of your ideas and experiences with flash as2 application? I already tried some feature but I really don’t know how to create a sliding puzzle. All I tried is to cut the photo into pieces using Adobe Cs5 photoshop software, add some information please. I need your solutions.
Chloe Chylly.
Hi Chloe,
First of all, you must have the required applications to be able to create your very own sliding puzzle.
You need to have Adobe Flash player because that is where you will be making your puzzle.
If you already have that software installed, download the free version of Sliding Puzzle ActionScript 2.0 from this link.
Unzipping it will give you several items inside: a Readme text file, license text, Adobe and Flash package files and the sliding sample folder.
Now as you mentioned you already have 10 different pictures you want to use for your puzzle.
Simply open the flash document in this folder and import your photos to create your sliding puzzle.
