All about how to scale stl file?
Hello experts,
All about how to scale stl file? There are some instances that we can make a scale for some files with any formats through the internet , or if there are some software that are going to fit with this kind of work please let me know.
Thank you.
Best Answer by Goram Ian
Answered By 60 points N/A #173577
Hi Rebecca Green,
There's a lot of site that is giving a information about scaling stl file. I have attached a link of a forum in which you can gather a lot of information that you need and also for your personal reference.
Autodesk Forums STL Files Scale
Thanks and more powers.
Goram Ian.
Answered By 10 points N/A #173576
To scale a .stl (solid works) file you can try blender and you can place the desired cube as given dimension and you will be able to scale the drawing.
Smith Thompson.
