Hi to everyone,
All about making payroll in vb to access. Is it possible to make a payroll system using visual basic programming language connect to a Microsoft Access database system? Please share and discuss with me your opinions so that I will be able to create this as a topic for my thesis proposal.
 Your suggestion is very much welcome.
Well, yes, it is possible to make a payroll system using a visual basic programming language. Connect to the MS access database system. For this purpose, you must be aware of the MS software and payrolls. It is more helpful for the management of a firm or a company for making payment to their employees.
Through this, they can directly access the employee records to see if they are paid or not. It is also beneficial for the employees.
For more details, you can visit this site.
Hello Travis Nelson,
Yes, you can create a Payroll System using Visual Basic as Front and MS Access as a database.
First is you must know the process of how the Payroll works. You may interview someone, usually from HR and Accounting Departments. Let them explain to you the step-by-step process as well as the data flow. You should be able to get an idea on how it works. Then translate those to your system and build a database structure based on what you got. You should also remember that different companies have different procedures and policies so don't mix them up.
Hope this helps.
