All about my galaxy s2 and pdf files. I have few questions about the compatibility requirement of loading pdf files in my galaxy s2 mobile phone. I hope there is a way to open pdf files by just using a mobile phone. Share with me the terms and conditions needed.
Isabella Barry.
All about my Galaxy s2 and PDF files.
Hello Isabella,
You will be happy to know that there are not any strict conditions for opening your pdf file in Samsung galaxy s2. You can use its default software to open them or you can have any third party application for this purpose. Foxit pdf, Adobe Reader are top applications for pdf files.
To download for your s2 visit this link:
http://www.mobiles24.co/downloads/tag/PDFViewer/samsung-galaxy-s2-apps
Try the following steps to solve your problem:
1) Download Adobe Reader for smartphones from android market, if yours don't have it.
2) You can open the pdf files if you have the right app for it, so , try the app "documents to go".
3) You might be streaming a lot, so meter your usage so that you won't exceed your limit.
Thank you.
