All about the nokia connector ipod. I would like to know if there are some available usb connector that will allow my nokia mobile phone connected to an ipod. For some transferring data reasons, such as songs, videos and images. Your suggestions will be much appreciated.
Waiting for your support, thank you.
Hi Pamela,
There are no available connectors/cables to connect a Nokia cellphone to an iPod. If you want to transfer songs and other files from your cellphone to your iPod, the acceptable way is with a use of a computer. But before transferring data, you should have to install Nokia PC suite in order to manipulate your files from your cellphone through computer. Also, in order to manipulate or add/remove files to your iPod, you should also have to install the latest version of iTunes for advising and tips for your iPod. You can transfer any video or music and images to your Nokia by copying it to your computer and sending it to your iPod with the use of Nokia PC suite and iTunes. Here is the link for Nokia PC suite download.
Hope it helps.
