All about technical question and answer service.
Hello techyv,
All about technical question and answer service. Except from techyv.com do you have any idea on other forums or website that gives a full and accurate information regarding gadgets, technology and internet related services? I would like to have an idea for future reference.
Expecting some help from you guys.
Best Answer by Imundada Jessica
Answered By 5 points N/A #166196
When it comes to technical questions and answer services, there are many site out there where you can ask and learn. By simply opening your favorite search engine and typing in a phrase like: "online question answer information technology", you will see a list of these sites. The format is basically the same: questions being posted by visitors, then answers coming experts.
Modestly aside, techyv has been my preferred site when I want to search for answers, because you'll be sure you're getting the most comprehensive and most concise answers coming from no less than experts from all over the net.
Answered By 5 points N/A #166197
Search on a Google will give you many suggestions on technical forms. As far as I have experienced you can find a solution for almost any problem by searching on the Google than searching on a forum. If you couldn’t find a solution for a problem of course you can post them in a forum but still better to choose a forum which discus your problem related issues specifically. Any way I’m providing you several technical forums that has very good user ratings. Please go through the below links
