What is vsprint8.ocx and also how do I fix all the errors related to this file?
All About Vsprint8.ocx File
OCX stands for OLE Control Extension.
Vsprint8.ocx is a file extension for a custom control file format used by ActiveX forms. This file is used for Interface behaviors that are controlled by programs like scroll bar and resizing movement.
If you face any problem with this file then I recommend reinstalling the file, but you can also try doing some of the fixes for this issue that I’ll be providing below:
- Try installing a registry repair tool to repair all the registry related problems.
- Scan and delete all the malware using any antivirus.
- Perform a clean boot of your PC.
Now coming to the steps of installing the file and pasting it to the correct path.
- Download the file.
- Extract the file to the path C:\Windows\System32, if you are using a 32 bit PC.
- Extract the file to the path C:\Windows\SysWOW64. Also, make sure to back-up the original file.
