Is there a precise all format video converter to avi that retains its quality? I have a lot of video files ranging from JPEG, Xvid, mp4, etc. and I'd like to convert them all into an avi file format. My PC is on Pentium 4 2.66 GHz and Windows XP 32 bit sp2. Thanks.
All format video converter to avi for Windows XP
There are many Video converter to Avi for Windows Xp. But, all of them I suggest you to use the Format Factory. It is a freeware software. So, you don’t need any license key to register. You can also convert Audio, image by using this software. You can also convert video into MPG, WMV, 3GP, FLV, SWF, MP4, AVI. You can also use the Any Video converter for it. It is also a freeware software.
So now download the latest version and enjoy yourself:
1.      Format Factory.
2.      Any Video Converter.
1.Total Video Converter is a total-featured conversion software that can support almost all video and audio formats.
video formats include:- .rm .rmvb .mp4 .3gp, 3g2 .psp .mpg .mpeg .divx .wmv .avi .flv .mov .mkv among others
TVC (total video converter) is also able to convert between a number of audio formats
2. xilisoft video converter also has similar capabilities with TVC and is compatible with windows OS versions starting from
XP sp2 onwards
