All My Files Were Deleted
I don’t know what happened to all the files in my computer, I did 10 documents and all of those files where deleted and I don't know where are those files. Someone help me how to look back everything. If its possible.Â
Hi Techdee2011_014,
    With the highest technology we had nowadays.  Anything now is possible.  Having our files deleted there's a software you have  to upload to recover your deleted files again.  Just make sure you choose the right software for you according to your needs.
   Download first the Data recovery software. After downloading it, you have to run the evaluation mode to be able to  preview all the lost documents or files that was lost or deleted.
   You have to buy the purchase activation product key to save the recovered documents.  Once the download was done no need to download it again.
   Do not forget to save all your documents from time to time to avoid these things.
Hope this might help you,
Thank you,
Ayessa
Usually those files are deleted that which files are not saved.I personally have been seen my own work was unsaved had been deleted from our computer.This is a melancholy that your unsaved files will not appear again in the monitor how many times you may tried.Apparently you should make your 10 documents without delay with a file name saved after finishing your document writing.You may lost your documents if it is unsaved.You may search the Recycle Bin for your lost 10 files and could copy and paste it into a blank new document page earlier.
Hi Techdee,
To recover your files, you will use a software called 'recovermyfiles'. You can get its trial version on the internet. Download and install it on your system.
Once it is on your system, execute it and locate the drive on which the files were before they were deleted and then choose the option to recover them.
Hope this helps.
___
Lee Hung.
There is a answer for any problem. You can solve this problem following this instructions .
Following these instructions.Â
If you save your documents correctly it can't be delete. If you do so,
1.Check recycle bin.
If you can't find out your document from bin then go to step 2.Â
2.Some times that files hidden.
You can check that this way
Start > Type "search" in start search box. > click "Change search options for files and folders"
> Now, Click on View tab .
Under View,
a)Select the radio button labeled Show hidden files, folders, and drives
b)Remove the check mark from the check box labeled Hide extensions for known file types.
c)Remove the check mark from the check box labeled Hide protected operating system files.
Click on Apply and Ok.
Then you can't be success from that 2 steps. Go to step 3.
3.If you don't know what is the place you save that files.
Use the search box on the Start menu.
You can use the search box on the Start menu to find files stored on your computer.
Input your file details and search.
4.Install a recovery software and start recovery. (Ex : Laid File recovery / Power Data Recovery / Norton Go Back)
You can download softwares through INTERNET..Then you can get back your documents.
5.May be there is a virus in your computer.
Setup an antivirus software and check your computer.(Ex : Mcafee / Avira / Panda / Kaspersky)
If there is virus you can remove it from that software.
6.After following 5 steps If you can't be success contact a data recovery expert.
After solving your problem don't forget to save your files correctly.
