All types of file player is the UMPlayer 0.98
Stewartyimothy,
UMPlayer is a multi format media player that supports almost all the media format files that we come across. RMVB file means Real Media Variable Bitrate, which is a simple Real Media file. It does not need any specific advanced players to open and view the rmvb files. UMPlayer can run this format.
There are also other players like WinX DVD, GOM and BS players. RMVB files can also be converted to your favorite format using the commonly used converters like My Video converter, Total Video Converter, Format Factory. There is also emvb specific media player available i.e. RMVB Player.
But it is better to use the player which supports multiple formats rather than installing this specific one. UMPlayer will anyway do a great job in supporting the RMVB files.
Charle Faru
The newly arrived UMPlayer 0.98 is an useful software. Will rmvb fortmat run by it?
UM Player .98 version support RMVB format. so you can easily run rmvb format with it.
Hi Stewartyimothy,
Itis MPlayer based multi-format media player. It opens almost every known audio and video format, and is very light on system resources. You can play almost 95% of media files by KM Player including RMVB (real media video) file. But some rmvb and real player formats do not go well with KMPlayer too.
It is best to use an application that supports a wide range of formats, especially when it also features numerous integrated audio and video codecs.
There are many software's which can be used for free to play rmvb files:
Real Player (Free version)
Install codec packs (Klcodec)
Mplayer
Smplayer
VLC Player
Kmplayer
GOM player
